VicS
I have an MCB and RCCB fitted on my 230v shore supply, this should give full protection should the earth path fails.
The mcb will give you overcurrent protection, as a fuse would.
An rccb or rcd relies on a return path to the neutral of the power source. Normally via the earth conductor. If this fails the connection to the water will still be sufficient for an rccb to operate oorrectly.
