billyfish
How often do you change gearbox oil . I do mine annually
Also, ATF has a very high loading of EP (boundary) lubricant, as gears do not develop hydrodynamic films.Interesting thread, I think I need to change mine more frequently.
I had to lookup what ATF is...... "A couple of differences are the following: Motor oil is designed to deal with the products of combustion, whereas automatic transmission fluid (ATF) does not see contaminants from fuel burning. An ATF is basically a closed system and the lubricant must last for a long period of time
So...are VP wrong in changing over to 15/40 engine oil
No, lubrication requirements are set by tooth loading and temperature. Presumably they have now decided they can go to a lower additive content.So...are VP wrong in changing over to 15/40 engine oil
