catmandoo
I have a Tank Tender fuel tank level indicator which works on the principal that if you pressurise a small bore plastic tube dipping into the fuel tank with air until bubbles come out of the end you can measure tank level by means of the air pressure required to keep the fuel out of the tube . All very well and quite accurate . ( Also expensive instrument )
However I have a problem . I get a different reading when the boat is moving about 1 inch of level !!! . It recovers when the boat is stopped . This gives me a problem on fuel consumption rate during long journeys
The 40 gallon tank is about 5 feet long , flat topped,semicircular , radius 10 inches , with 2 baffles . It runs fore and aft .
Fuel is extracted at one end and recycled back to the other end from the diesel engine injectors etc
Three possibilities
1 When the boat is moving it tilts towards the return end . ie the stern dips .
2 The return end gets hotter than the supply end due to heat from the diesel engine injectors and with no mixing due to the baffles and poor convection currents the difference in density results in a depression at the level gauge end ( U tube effect )
3 a combination of both
Any comments as as to cause and suggestions on how I can get an accurate reading when moving without relocating the position of the tubing ???
Any instrument engineers out there ?????
Three possibilities
