Crinan12
My outboard stopped working so I took the carb apart to clean it. I put it back together and it started straight away.
However fuel is now leaking, it seems to be coming from the bottom of black plastic air box thing although it's quite hard to tell.
Could this paper gasket be the culprit do you think? It has a crease on it so it's not perfect. Or is it likely something else?
There is another circular rubber gasket on the bottom of the carb bowl but it looks okay.
