Fuel gauge issue
Meps1983
17 Feb 2022
Morning all
I know I'm not the first to post and won't be the last but I'm stuck with my fuel gauge. Its works intermittently with the ignition on, swinging between 1/4 of a tank and completely empty.
Voltage at the gauge is good (12.4v)
I've "jumped" the ground with the signal wire and the gauge flies up to full so I think the gauge is good.
I've jumped a ground from the battery straight to the sender, and I've jumped the ground and signal back to the gauge with separate wires....and still have the gauge jumping between 1/4 and empty!?
Next I removed the sender to check it was working and that moved the gauge up and down as expected. So what am I missing? Any guidance will be much appreciated. Thanks for reading. Ben
billskip
6 Sep 2001
Float chamber half full with fuel (Not floating correctly)?
Take the sender out and measure the residence as you move the sensor/float?
bluetooth
30 Dec 2015
Poole
How old is it?
I had same with 15yr old water guage and a new sender was needed, and sorted.
Not mentioning diesel ones so as not to tempt fate!
vas
21 Jun 2011
Volos-Athens
if the problem is in the cable, a new sender will not help a lot.
however since you jumpered the lot and effectively bypassed the original cabling. There's not much else to do.
Mind, is the 12.4V constant with engine running and overtime?
I've spend a few good hours sorting out my mate's P45 water tank sender/gauge combo. it was a damaged cable to blame after all (and a sticking sender which was easy to fix/clean with a bit of alcohol
so if you just have the sender off, slide the thingie to 3/4full and leave it there, gauge is stable?
can you find the 1/4 spot in that setup and see if the gauge is also stable?
V.
Meps1983
17 Feb 2022
I shall have another play around with the sender tomorrow. The gauge went up and down smoothly when I had the sender out of the tank. I didn't try to see if it sat at 1/4 of a tank as you (Vas) mentioned.
I'm gonna check the wiring once more too
