woolleyhatter
greetings fonts of all knowledge.
As i'm sure you're aware i'm a proud owner of a FB, and whilst it still is only a hull, i've come across a few probs.
Currently i have great access to the keel bolts, and as i'm fairly sure they have never been replaced, should i replace them now whilst i can, and if so how exactly do you replace the bolts??!!. Whilst i have done a keel in the past, it was easy because the keel was off and it was simply a case of knocking them out and putting new ones in, but i don't really have the opportunity to remove the keel.
And furthermore there is a crack (approx 12' along the grain) in transom. It is exactly where the gudgeon is fixed for the rudder, and although you can see through it, it is the only fault in the transom which is in good nick. Should i replace the whole transom or fill/bond with epoxy??.
As always your help is appreciated, and happy new year to you all.
