fog horn gas
obmij
30 Nov 2005
Anyone know what it is? Buying the plastimo refills could get quite expensive given how long they last!
William_H
28 Jul 2003
West Australia
You might like to try an air pump from car air horns running on 12v. Or try an old gas cylinder filled with a air from a car tyre inflator air compressor.
As said the best way to store a lot of gas is to use a gas as a liquid that has an appropriate pressure at room temp as it evaporates. Some hydrocarbons have this characteristic ie a gas liquification / evaporation pressure of 50 odd psi at 15 degrees C. A higher pressure would require a reinforced can a lower pressure not make a noise. Although temp would make a lot of difference. (I am guessing)
good luck olewill
blenkinsop
25 Oct 2008
Look up the Ecoblast air horn. You pump it up with a bicycle pump (supplied) and hence the compressed gas is air! Available from Gael Force.
Performance at least equal to non refillable canisters.
