Fitting sea cock, head outlet.
VicS
13 Jul 2002
I'd use a jointing compound on the thread, or even a sealant such as Sikaflex, but I would also fit a lock nut so that the valve can be positively locked in the required position, not just screwed on until it becomes tight on a mass of tape.
Ideally parallel threaded fittings joints should make the seal on a joint washer between flat faces not on the thread itself. (Tapered threads make the joint on the thread)
