johnalison
The plotter in the cockpit is clearly desirable, but the advantage of having it below is less with tiller steering, when you would have to leave the helm to operate or maybe even view it, depending on the boat. Plotters were not waterproof unless bulkhead mounted when I fitted my first one 24 yrs ago, so my solution was to fit in at the chart table and have a graphic repeater in the cockpit displaying up to four parameters, and later a tablet as well for occasional use. No solution is perfect but this works fine for me and suits the boat.Our plotter is bulkhead flush mounted in the cockpit. It never crossed my mind to have it down below. Why bother with all the info if you have to go below to get it. Look at your ‘plotter’ as just another big instrument display. You may not need full screen chart all the time, you can put speed, wind, and/or depth on display, maybe with your networked displays on the other side of the companionway. Tacking up a shore line, that is a real asset.
