Fenders
Con_Brio
31 Oct 2002
I think you are supposed to be able to reinflate fenders that have gone squashy. But how? The tiny hole doesn't look like a valve and wouldn't accommodate any of the selection of inflator pump nozzles I have. Advice, please.
AndCur
9 Oct 2003
Use the air line at your local garage. It wont be a perfect fit but will do the job.
StephenW
21 Feb 2002
UK
You need to buy a needle shaped adapter that will fit into the fender valve and fits on the end of a bicycle pump or fender pum (Compass do a fender pump with adapters-about £6.60)
Jools_of_Top_Cat
16 Dec 2002
Yup, I bought one of those, it is the same as the football adapter, there is another adapter I got from compass marine at a jumble when I picked up a couple of new fenders this year, it is a small plastic jobbie, that allows you to screw a car pump type clamp to it.
After killing myself to get a pathetic amount of air into the fenders with a bike pump, I took them to the garage, perfect and luvly jubly.
<hr width=100% size=1>Julian
Gordonmc
19 Sep 2001
Loch Riddon for Summer
Anyone know how to keep air in a Plastimo fender?
The pump adaptor is cone shape which fits into the hole in the fender after a similar shape plug is taken out, but there doesn't seem to be any valve to stop the air coming out before the plug can be screwed back in.
Very frustrating.
seaesta
13 Sep 2001
Whitby, Yorkshire, England
I have a really big fender like you describe with no valve. The season before last it was badly inflated and I could not seem to improve matters. In the end I waited until a very cold winter day- opened it up - footled about until it was reasonably full and closed the plug very firmly. As the season approached and the weather warmed up the fender was reasonably full and tight. I expect you could do something similar with a big deep freeze!
Martin of Whitby
