Refueler
Going back to the OP.
Why are you "fed up" with something that is doing what it is intended to do: protecting the furled sail from sunrise to sunset. The fact that it is now in a bad state indicates that it has indeed been working, in much the same way that an anode that is pitted and lost much of its zinc shows that it has been working.
Removing the UV strip is only an hour or two's work. Just go to a sewing shop and get a seam ripper, a small forked blade with a handle, the bottom fork slides under the stitches and the thread is cut in the fork. Replacing the strip is no more than two days work, probably a lot less, to cut and sew on with a sewing machine. I used light weight tan sailcloth from ebay because the tan fades as the cloth is degraded by UV giving a visual indication of its state. Putting it on in sections the width of the cloth (minus overlaps) took care of the curved edges of the sail.
If you chose to leave the strip off the sail will rapidly deteriorate. Even hank on sails suffer from UV degradation when well used. While looking at a 42 ft sloop for sale in the 80's the heavy working jib felt brittle. The owner said he would get in valeted. I suggested it was beyond that and asked if I could tear it. He said yes and looked at me as if I was mad. His expression changed rapidly when the sail cloth tore along a line of stitching as easily as perforated paper.
The sail flogged and UV strip was shredded as its so light ..................
I have my reasons ....
Tks for idea of the seam ripper ....
