Daydream believer
Why do you not just use one halyard & take that through a mast aligner? That is what I do & it works- Or has done until now, but I have just had a new furler fitted so knowing my luckHalyard hoists sail up furling gear as usual ... a second lighter line via a small block on mast front is also connected to halyard swivel. Hoist sail by the two lines .... halyard made up hard as usual .... lighter line as you see in picture is at good angle to furler and made up tight to stop halyard wrap.
It is an actual recc'd system if 'doughnuts / bent shackle' fails to stop wrap.
As a comment aside-Your second line looks as if it is a little low down & must restrict the length of sail luff that you can have. An aligner on the mast, just above the top of the foil would surely be better. Especially when swopping sails. If you have to go under bridges & hoist & drop the mast ( I think that you said that they were an issue) hoisting & lowering sails must be a nuisance with 2 lines.
