jamie N
If your engine's a "GM" something, you're in a good place here, as you're treated to 100's of thousands of hours experience with these, plus a couple of bits of useful advice.
Down wind I let my backstay slack. Upwind in a blow I pull the 32:1 tackle in hard. However, I have a 11/12 rig. But that being said any backstay should be perfectly able to take a person swinging on it when moving round the boat in a clumsy action. Are we suggesting that such an action could bring the mast down? A boom is much less.The backstay takes a lot more strain from the genny in a decent blow than the weight of the boom could exert. The little bit of strain from the weight of the boom on the backstay would be on the forestay really. Those two stays take the force from the wind heeling the boat, that’s a lot more force than gravity on your boom
Probably right. Trouble is that sod's law says that it will always go wrong 3 miles offshore. Not when one is sitting at home typing on laptop to the forumIf your engine's a "GM" something, you're in a good place here, as you're treated to 100's of thousands of hours experience with these, plus a couple of bits of useful advice.![]()
She's never going to win any races, but she seemed a little faster, but that was a different day under different conditions, and most importantly, with someone on board who knew what they were doing.did She go any quicker under sail?
I should note that the very slow motor-only pootle featured a lot of faff, trying to work out if the exhaust gunk was a sign of impending catastrophe, and so we spent a lot of that time running at low throttle.
Thanks again all for your invaluable input - there are a number of opportunities to bug-out along the way if we end up making particularly poor time.
I sailed 50 miles with no topping lift, The only time it might get iffy is when you need to reef or bring the sail down.I know little about in mast furling and their main halyards, but if you can’t repurpose that halyard, and you are intending to motor, do you have a spinnaker halyard that could be used as a makeshift topping lift?
If you are intending to sail, doesn’t the mainsail support the boom when unfurled making the topping lift unnecessary underway? I don’t have any tension on my topping lift when under sail.
Be good to see a picture of how badly fouled she was !Hi all,
Quick update, my friend and I successfully made the journey yesterday, despite all of our best efforts to the contrary. Something is clearly not right with the boat because we managed 4.6kts with the engine going full beans, the jib out, and a 12-14kts tailwind. We were getting overtaken by the engine exhaust.
Getting hauled out in the next couple of days so the exciting and doubtless wallet-hurting voyage of discovery can start.
Thanks again for all your suggestions, I don't doubt there will be many more idiotic questions from me in the next few weeks
Ed
Hi all,
Ed
We tried a couple of times, once with the wind off the port, and almost immediately lost steerage and drifted towards the leeward shore. Then we tried again when running dead downwind, our speed dropped to about 2.5kts and with daylight wearing on we elected to continue motorsailing.Glad you made it. Did you try stopping or disengaging the engine?. I suspect that the propeller spent most of the time thrashing the water and trying to keep up with the rest of the boat.
When put that way it does seem like I said something very sillyIf the tail wind was in excess of the boat speed why would you except the exhaust smoke to be different?
At least you had the wind with you as the beating through the east kyle makes for a long sailWe tried a couple of times, once with the wind off the port, and almost immediately lost steerage and drifted towards the leeward shore. Then we tried again when running dead downwind, our speed dropped to about 2.5kts and with daylight wearing on we elected to continue motorsailing.
I'm certain that the sail was incorrectly set up, I blame the skipper.
It struck me at the time to be a sign that something was amiss, as well as providing an indication of true wind and confirming that we were indeed running dead downwind - the boat doesn't have a working log or anemometer and GPS on its own isn't enough to tell the full story. I really can't recommend using diesel exhaust as instrumentation, though.
