Exterior Varnish
jfkal
17 Aug 2001
Singapore
Grrrrrrrrrrrrrrrrrr. Has anyone come up with a TRUE UV resistant varnish? Am using International but the stuff is always gone after not more than three month. Any alternatives?
Chris_Robb
15 Jun 2001
Haslemere/ Leros
I have varnished teak, which people always say is the most difficult.
I put the first coat on 4 years ago, with a minimum of 7 that first year, then 2 coats a year since, the lustre keeps improoving all the time. I always thin by about 10% which makes it easier to apply.
I suspect that you are not putting enough coats on initially. anthying less than 4 is just a waste of time.
I use either blakes or International, which ever is available.
ccscott49
7 Sep 2001
Try Coelans, german product, expensive, but brilliant stuff, I use it on teak and iroko on my boat in Portugal and the med, two years and not a mark on it. The blurb says it will last eight years in med weather from what I've seen already I can believe it.
jfkal
17 Aug 2001
Singapore
I tried to find info on that product but the web yielded nothing. Do you have more info i.e. manufacturers name, where to buy??
THX
I had the same problem on my wooden mast and boom. A few seasons ago I applied a product called Deks Oilje (sp???) It is a two pack product.
It has been fantastic. The application was a bit tedious but the results and wear have been great.
Cheers
I've used Le Tonkinois (see PBO 419) for some years now and found it to be excellent in all respects - and if you have to revarnish small areas you can hardly see the repair.
The french navy have used it for years. It can be a little more demanding to apply - it's got no anti-bubble or anti-skin additives like many modern varnishes.
And for the sake of good order it must be said that my ex-wife is the importer here in Denmark, but believe me, it's great stuff - and yes, it does stay on teak and brings out the colour very nicely.
Lost in Denmark - a yachtsmans paradise!
ccscott49
7 Sep 2001
Re: Coelan
Aqua Marine are, I believe the importers for UK, and they have all the blurb etc.
