Expired UK Passport?
I'm a dual citizen
So when your dual citizenship other passport expires are you going to renew it? or do you think you will be able to persuade them of your rights?
Anyway good luck with your experiment, I would have thought the exit woud be more restricted. Of course they may not let you leave the UK without a valid UK passport should you wish to leave.
I know in Venezuela if you are Venezuelan and have multiple passports you can only leave Venezuela on a Venezuela passport.
Good luck 👍
Good luck 👍
The UK doesn't have exit immigration so that wouldn't be an issue. At least not from airports. And there is no restriction on which passport you can use in order to leave anyway.
There is a passport check to ensure that you can enter the country you're going to but not traditional immigration.
As stated, the problem will come at Calais at the ferry.
As for as I understand it, all UK citizens have a right to abode in the UK.
Right to abode is not right of entry.
AFAIK, the UK has no legal right (under current laws) to force UK citizens to enter the UK on a British passport (unlike, for example, America). Transport carriers can refuse boarding, but that's (much?) less likely to be an issue at Calais/Dunkerque due to the juxtaposed border controls. The Home Office threaten possible delays and additional questioning at the border, but they don't seem to categorically state refusal of entry to the UK for UK citizens as a possible consequence - I don't think that they legally can... Time will tell!
That's exactly what is changing... the new law expressly forces UK citizens to enter the UK on British passports. Rocking up at Calais with your non-UK passport that gives a place of birth in the UK will gain you a firm 'No', no matter what driving licence your flash at them. You'll be left to enjoy Calais while you await the issue of your new UK passport.
Maybe you're right, but my reading of the matter suggests that there isn't actually any change to the law, and the Home Office's response when questioned has not been to quote chapter and verse, but instead to "strongly advise".
Will British dual nationals really be forced to have a valid UK passport from February?
All that said, I'm probably being overly optimistic!! 😂
If travelling to the EU, it's recommended that you exit on the EU passport.
I am probably wrong, and don’t have skin in this particular game, but I thought the recommendation was to exit the UK border with your UK passport but present your EU passport on entry to the EU?
It avoids a mistaken Schengen event being logged. The reverse order used on return again stops you being questioned about your Schengen rights.
It means that each territory can record movements of their legal citizens, deters erroneous immigration statistics and helps control the blood pressure of the Daily Mail staff.
That's exactly what I did last week for Leshuttle. UK passport to UK border control when leaving, Irish to French passport control 100 yards later. Reversed procedure at Calais.
Well it is really once citizenship has been established. UK citizens have an absolute right of abode and an absolute right of entry. In fact what happens is that UK citizens are completely exempt from all Immigration control - once their citizenship has been established. That has not and is not changing.
The difficulty, as has been said, will be getting the transport operators to take you and that will be the sticking point. Once the person actually reaches the border then it's a relatively simple check to clarify if the person is a UK citizen if they don't have the required documentation and once that's done they are then exempt from immigration control.
Presumably if someone sails across themselves - by yacht for example - then they could reasonably enter on their expired UK passport once they reach the UK (I'm not too sure how it works sailing to and from France these days - i.e. whether you need to check out of France - haven't done it for years). There might be a discussion with Border Force on their arrival but realistically they can't refuse a UK citizen entering their country. But it's a niche situation really.
Obviously the best method for dual citizens is to have a current UK passport as it avoids all these problems which has been said.
I do feel that syvictoria may experience issues as when they travel by ferry, since the ferry check in procedure occurs prior to the immigration and I'm not sure whether they'll allow them to travel once they see that there is no current UK passport or ETA with foreign passport. It will be interesting to see!
Failing that then just get an Emergency Travel Document assuming they are currently out of the UK. If they are in the UK then just get a Fast Track passport.
Electronic travel authorisation (ETA): guide for dual citizens
Had a notification that the above page has been updated again today which prompted me to re-read it. The important section with regards to this thread is:
Travelling on or after 25 February 2026
You may not be able to board your transport to the UK without a valid document.
You will need to have additional identity checks to verify your citizenship before you can go through UK passport control.
Apply for a passport or a certificate of entitlement now. It will avoid complications when travelling to the UK from 25 February 2026.
