Tranona
Quite right, because you grasp the issues. It's a educational resource to show people that adding weight aloft is fine, within limits. Depending on the boat and the weights involved.
Most people understand mass produced designs are cut from the roll.
You buy a boat; choose one set of options it will be less stable, choose others it will be more so. The designer has done his sums to stay out of courtroom, in either case. The only stability information you will be given is lightship, standard trim - if you are lucky.
Only the chronic optimist will take this as evidence that both options are the same.
You really do seem to see ill where none exists.
Have you read all the material I suggested?
Suggest you read posts#24/25/26 which clearly shows (assuming the secondhand account is correct) that builders do calculate stability for optional combinations and adjust the category if necessary. You will find it quite common for boats to be in different categories with different options, usually around rigs and keels as they have the biggest influence over stability. This happens particularly in the 30-35' size range which straddle Cat B and A
It would be very helpful if you gave the source of all your pronouncements as surely what you say is based on your ignorance as you provide no evidence to support them and indeed what evidence there is says you are wrong.
Perhaps if you really knew what you were talking about you would not have to rely on your favourite "everybody knows" which you use to hide your ignorance.
