Excellent vid of rescuing a Yacht off a beach
William_H
28 Jul 2003
West Australia
Rescue
A fair bit of comedy of errors especially after getting it to float.
Certainly expensive with earth movers and cranes.
We got to rescue a 34ft boat on Wed night. Very gentle conditions he just missed the deep water mark and motored onto the mud. On a slightly falling tide. We happened to be nearby in the club rescue boat and actually watched him run aground. We received a rope from the bow and tried to turn the boat towards deep water moved it a bit then it was stuck again.
The skipper then asked us to take a halyard and use the rescue boat to heel the boat. She then cam off under her own engine quite easily. It is a rescue method I have often wondered about. It is a bit scary to apply a RB pull to the top of the mast. Visions of it all tumbling down under too much load. As it happened there were no worries. All over in 10 minutes.
Thinking about the rescue I realised I had made the mistake I have told so many people not to make. "Ask the skipper what he wants" don't try to dictate how the rescue is to be done from the RB. In hind sight we should have simply pulled the boat out backwards in the same path it went into the mud. The chosen path was across a longer path of mud. anyway we got some amusement and he was grateful.
The funny thing is a smaller 19ft fin keel yacht cam past in the other direction he went way inside the deep water marks . We watched amused and even yelled at him and waited for the characteristic hull stop, mast lurch forward of a grounding. Somehow he got through it being high tide. The one who did run aground must have been watching him and not concentrating on steering.
We have a roster to operate the RB an 18ft Al with 140HP inboard/outboard when we run the twilight races. It is mostly a token gesture but good for towing in boats without engine when the wind drops. Now only about 3 wed twilight races left for the season. This was however a beautiful evening. Temps 15 to 31. all good fun olewill
bikedaft
16 Dec 2008
tayvallich
how did they get the slings on whilst she was on the beach?
have always wondered about shovelling sand away from keel/underside of boat, but would worry whole thing slid on top of me mid shovelling...
love the push from the digger on the stern
rob2
23 Aug 2005
Hampshire UK
I can't understand why they risked pushing the stern with a digger! There was a line rigged to an anchor to pull her bows out, so why didn't they tow her out by hooking it to the digger and driving up the beach? I guess there isn't any useful tidal range where this happened, else it would have been so much safer to wait, once lifted to the water's edge.
Mind you, with a crane, a digger and a diver in the water, I guess this wasn't a cheap exercise. Let's hope there wasn't too much damage to a rather nice looking yacht.
Rob.
fireball
15 Nov 2004
Just wondering why they didn't crane her down further to the water before the tide came up ... and I couldn't quite work out why they did a tow strop around the keel ... I don't think the line from there round some block or other further out and back to shore did much... !!
WH used a technique I've used before - take the halyard from the masthead (mast head rig) and use that to tip the boat on her side - she draws a bit less then...
There was a tender floating about - that strapped to the halyard would've provided quite a bit of heal ....
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
We went aground in the Bahamas, there are two charts and a pilot book and they all differ as to where the shallows are, most of the area has no more than eight feet depth the most we saw was 12. We used our dighy to lay out an anchor attached to a rope attached to a halyard. Tipped the boat over and got off. It's very easy thing to do and defitinitley no risk to it.
Mrnotming
1 Mar 2005
Dublin
Using Halyard from Masthead to pull off when grounded.?
Done this more than once, yachts don't seem to mind and its quick!
Give two halyards if masthead rig and you are worried!
If you're on the putty in a mobo, a line to the midships cleat and over the cabin top to the rescue vessel will heel your vessel enough if single keel displacement type hull.
Bilge keeled yachts and similar mobo's need not apply!
Lucky lift-keelers just lead the rest of us onto the putty!
Emjaytoo
23 Jan 2005
Us: Kent; Emjaytoo: Holland; Kate: Conyer Creek
www.emjaytoo.net
Dragging A Boat Off The Mud
This is a technique used by the KNRM in The Netherlands.
geem
27 Apr 2006
Caribbean
We had a weather system go through the northern Caribbean a couple of days ago. Westerly winds gusting over 30kts. Not in itself much to write home about, but the wind was from the west. A friends trimaran went up on the beach. A couple of us had a very wet hour dragging it off the beach using aluminium anchors and the genoa winches on the tri. We got it afloat. When the owner turned up, we got the engine going and got it clear of the beach. I got back to my own boat for a hot shower and we turned the heating on. It turns out that we had the coldest February temperature ever recorded in Antigua. About 20degC. Its funny what you get used to after 3 years in the Caribbean
Bouba
6 Sep 2016
SoF
The yacht in the picture is quite interesting (if I recall correctly)...we have storms overnight and can get half a dozen boats on the beach...these are moored to buoys with concrete weights on the sea floor....so many boats break free every year that no one bothers now to moor up during the winter on that beach. All except that catamaran...it’s always there year after year and it’s never budged...and last night wasn’t even that windy...I guess sea floors move and chains rust...
William_H
28 Jul 2003
West Australia
"I guess chains rust" Yes they do at an alarming rate. I can't imagine a good chain failing in a storm. Even if weight onb the bottom moves a boat will not usually come ashore because weight will continue to drag and eventually halt the movement. But chains fail or ropes chafe that is usually why boats end up on shore. The evidence is usually plain to see in tackle still attached to the bow. All that assuming the bow hardware holds. Our local mooring authorities have mandated a professional inspection of all moorings every 2 years. Yes a real pain to boat owners but much fewer boats on beach now. geem is complaining about weather. (cold) We have had heat wave after heat wave 42 max last 2 days with min. around 24 overnight. Record number of days over 40 for Feb already. Cool today for sailing only 39 max. ol'will
Baggywrinkle
6 Mar 2010
That’s one of the scariest things I have ever seen 😱
ps. Beautiful yacht
Looks scary, but when the bags hit the water their mass disappears as the bag contents are the same density as the water - so the boat can't go over any further than the length of the halyards - and you control that with the winches. The bags can be swung out using the helm. To retrieve them just let out the halyard or rig a line to dump the water.
