Engine wont start!
stu9000
8 Mar 2008
near kingston upon thames, surrey
I'm bobbing on my Blackwater mooring. Beautiful day but I just cannot get the engine going.
I've changed the filter and the lift pump.checked the bowl and bled to the bolts on injectors. Poured some wynns into the bowl. Tried wd40 into air intake. Batteries OK.
Any ideas ?
stu9000
8 Mar 2008
Compression issue? Can i take injecors out and soak them in diesel? Fuel looked clean when I changed thr filter. But I'm wondering if the injectors are clogged. VP 2003. 1987 so an old girl but reliable till now. That said It didn't start when I brought her ashore in November. Before that she has been good. If not used for a month the engine start routine would need to turn over for maybe 20 seconds to get going. About 6 pumps on the stop t was also required. So, compression? Or air intake? That has not been looked at for a while.
garymalmgren
28 Jan 2017
So we are talking about an engine that turns over (at a good speed) but will not fire on any cylinder.
How many cylinders is the engine/
What make and model?
How long is it since it last started?
gary
38mess
9 Apr 2019
All over the shop
The do have a cold start procedure. If you don't follow it they will never star. I had the same engine 20 odd years ago but can't remember the procedure. Someone will come along soon who will know
garymalmgren
28 Jan 2017
3 cylinders.
None firing,
Fuel.
Start from the tank,
Bleed, again.
I know that you have bled already.
Do it again slowly.
Don't worry about the mess, You can clean it up later.
gary
stu9000
8 Mar 2008
Looks like I'm not going to get her going this weekend. I'm wondering now.what the next step is. Remove injectors maybe. I've never had them looked at. But I don't want to break anything getting them out.
Maybe i need to get someone on board to have a look first.
Mister E
16 Nov 2015
Try leaving 2 injectors loose and tighten on up.
Then turn the engine over and see if it tries to fire.
If it does tighten one of the others and see how that is.
Stemar
12 Sep 2001
Cold start procedure - at least 3/4 throttle - if it's being stubborn, full throttle, but you want to be near the throttle! Pull out stop control and push it back in. Let it churn. Mine used to want near full throttle if it hadn't run for a while, or it was a cold day.
If that isn't doing it and the compression's OK, crack the supply union on each injector in turn. Fuel? Tighten back up. No fuel, check the output from the lift pump on the engine.
stu9000
8 Mar 2008
Thanks. Tried this. Even changed the lift pump out. Fuel getting to the injectors I believe.
