TomSummerbird
New Member
Hello, i was hit by a breaking wave just before passing behind the breakwater at Brighton Marina the other day and the engine cut out. It started first time, then stopped again a few seconds later, then I started it again and it ran fine. But it was a genuine “oh s**t” moment and shook us up!
My engine (a Volvo d2-50 with sail drive) is set up with all the parts shown on the diagram attached in terms of the exhaust, which I am assuming was probably the culprit. However I note I had quite low revs on at the time and I supposed a stall might be another explanation.
My questions are firstly, is this a normal occurrence given a properly set-up exhaust system? Or is there likely to be something that needs to be troubleshooted or changed? Finally, is there any maintenance I should do because of the incident itself / damage it might cause?
Thank you for any responses.
Tom
Tom
