Andrew_B
In summer last year I installed an Air Marine X wind generator on my Hunter 34.
As per the installation instructions I wired it through an amp meter and directly onto one of the batteries.
It works great!
The only trouble is I have 2 battery banks.With the battery switch on 'Both' all the batteries are linked and charged.
If only one bank is selected then of course only the battery the Air Marine is connected to is charged.
If I link the Air Marine to both banks then I will not be able to isolate one bank from the other as they will be joined through the generator.
If I wire the Air Marine through the battery switch then again I will have to select 'Both' to charge both battery banks.
Ideally I would like both banks to be charging while only 1 is selected.
Is there such a thing as a one way voltage device I could wire between the Air Marine and the 2nd battery bank so it gets a charge one way but not the other or should I be doing something else?
Many thanks for and help.
It works great!
