eddystone
I tend to go a bit gaga faced with 12V systems on yachts, including my own. Couple of questions:
1. I know you can get spade extension terminals, like a little Xmas tree, but how to extend the negative connection block behind the switch panel? Mine is like a bar with holes in it and it's rammed full.
2. I want to fit a red/white chart light on a "wand" could I take a spur off the wires leading to a light fitting above the chart table?
3. Want to fit a surface mounted 12V/USB dual charging socket above the chart table - could i solder the wires to the ones coming out of the 12V socket on the switch panel?
4. Need to fit a new bulb into the bulkhead compass (Plastimo) It has in incredibly thin twisted 2 ply flex. Is this uni polar or is there a positive and negative? And should I step this up to a thicker cable with a connector to go into the back of the compass switch on the panel?
