Neeves
Electric winches are old news and portable powered handles, a bit more recent, but also old news.
There was a recent article on electric winches and portable powered handles in YW
iWinch test: new electric winch handle option - Yachting World
In which a drill bit accessory can be bought allowing you to use a reasonably powerful drill to drive a winch. It fits in the same way you might fit a screwdriver into a drill - simple stuff.
The reason for posting is that I note the attachment for the drill can be bought from Force 4 - and to me, being a parsimonious Scot, think it to be extortionate (but then it is for marine application and specifically for leisure marine so I should expect it to be pricey - but not soooooo..oo pricey.
Coincidentally a couple of years ago I had some 5083 aluminium alloy, surplus to requirement, I'd had need for a 20mm thick slab, and I cut a piece out and ground it to fit a winch - its a simple square section. I drilled my piece, tapped it, which allows it to take a little chopping board and the bolted assembly sits on our main sheet winch and is just the size for 2 whisky glasses. The single bolt I use to secure the flat surface to insert is the same size as accepts a camera. I can secure a camera (if you remember what old fashioned cameras were like), or moving to the end of the 20th Century - or it will accept a Go-Pro to any of our winches. With a slight modification I could use the same piece of aluminium with a different bolt to use it in a battery drill - and power any winch.
Now I never thought my idea merited any attention, it seems simple and obvious so I have taken no pictures. Now that I see the price that Force 4 is charging Stg47!! - I thought I'd air the concept.
I don't recall the size you need to fit into a winch (11/16th" ? - you need to check) - but if you have winch handles they are easy to measure and are all the same size. If you just want to fit to an electric drill you need to tap a hole down the centre - it has to be central - and use a high tensile bolt (and Duralac). You might want to grind the bolt, give it some flat sides, to make it more secure in the chuck, secure a nut to the bolt with blue Loctite - the bolt head and nut can be recessed into the device.
Or you could simply buy from Force 4
Take care, stay safe
Jonathan
Jonathan
