Wansworth
A possible purchase has appeared but it has an electric toilet which I have to admit seems a bit extravagant…..are theya good thing or another thing to go wrong ?
Buses are very infrequent hereabouts but something to take into account!My friend installed an electric toilet on his boat and a few days later he was hit by a bus whilst crossing (on foot) Leytonstone High Street. Coincidence? Maybe. But maybe not…
Yes there have been several rathernondescript boats fitted with electric bogs that have put me off but this Cobra seems worth looking at …..a porta pottie would easily replace itMake of bog might help but in the size of boats you are looking at it seems a very odd addition.
In order of things that can go wrong:
Electric bog multiple items from wiring to macerator
Manual Pump maintenance some easier to maintain than others
Bucket you throw the bucket overboard
Thanks,not looking goodMore trouble than they are worth IMO.
My boat has two heads, one electric and one not, the electric one uses a lot of water, significant if you use a holding tank, is noisy especially if used during the night and takes a fair few amps from the battery. Also, if you don't want theimpellermacerator to rot out you need to do a last flush before leaving the boat with fresh water.
If and I know it's a very big if why replace a plumbed in bog with a stinking bucket with a lid, the marine equivalent of a Porta loo, if and when it breaks just replace with a pump model as you would have all the plumbing already installedYes there have been several rathernondescript boats fitted with electric bogs that have put me off but this Cobra seems worth looking at …..a porta pottie would easily replace it
I had a porta pottie in the Albin Vega and it was not smelly and here in Spain by law you cannot use a pump out toilet in harbour waters u less you have a black water tank.Anyway all rather jumping the gunatthe moIf and I know it's a very big if why replace a plumbed in bog with a stinking bucket with a lid, the marine equivalent of a Porta loo, if and when it breaks just replace with a pump model as you would have all the plumbing already installed
If the boat is in Spain with a "traditional" bog and I do understand that to some a bucket is traditional, then it is most likely fitted with a holding tank. It's not rocket science more your bog standard marine engineering.I had a porta pottie in the Albin Vega and it was not smelly and here in Spain by law you cannot use a pump out toilet in harbour waters u less you have a black water tank.Anyway all rather jumping the gunatthe mo![]()
It’s quite possible the bog in question just goes over board although illegal I have been on boats were although they have the five year certificate are flouting the law…..and the owners laughIf the boat is in Spain with a "traditional" bog and I do understand that to some a bucket is traditional, then it is most likely fitted with a holding tank. It's not rocket science more your bog standard marine engineering.
We are all assuming a macerator toilet, hope its not an incinerator type!
C'mon - its Wandsy we are talking about.An electric bog would not be a reason to reject a boat, it's a minor problem if it is a problem, there are far more items that should and probably will figure much higher on a rejection list.
He is LOOKING for a reason not to become a boat owner!
Will check out joker valvesWe had a Jabsco Lite toilet for many years. When it was working it was great, particularly for those aboard with arthritic wrists. Its major problem was that the flush volume is minimised to avoid filling a holding tank quickly but this encourages salt accumulation. If you don't mind cleaning joker valves several times per season they can be worth having.
I've used aqua fuerte a lot on both manual and electric heads. Saved a lot of maintenance over the years. A short flush through with some fresh water afterwards doesn't seem to affect rubber seals.Will check out joker valves![]()
