Electric outboard to fit through centreboard casing?
Nicholas Blyth
3 Nov 2022
Hi,
This is probably a daft one but I have a classic wooden sailing dinghy that I would like to power by electric outboard occasionally, without spoiling the look of the boat with a transom mounting.
Does anybody know of an electric outboard that can be mounted on and posted through a fairly small centre board aperture? Clearly, either top or bottom will need to be fairly easily detachable without risk of ruining the machine. I doubt if I’m the only one with this requirement?!
Puffin
dunedin
3 Feb 2004
Most dinghy centreboard cases are circa 20-30mm (an inch plus or minus a bit) wide.
How would you get a propellor up and down through such a narrow gap?
Clearly it might be possible to find a cheap low power trolling motor and split it such that the lower end is attached permanently below the surface, and a cable only is passed through the centreboard case up to a battery and controller. But then it would be permanently below the hull, causing drag and preventing coming into shallow water. Also likely preventing use of the centreboard for sailing.
So sounds like a non starter. Or have I misunderstood your idea
Nicholas Blyth
3 Nov 2022
Good morning,
Many thanks for this feedback. The aperture is 3.5cm so fairly luxurious:) Yes, thanks, I am posting in the hope that a ready-to- buy solution may be suggested, but realistically I’m looking at whether it would be feasible to adapt an existing inexpensive trolling motor by making a split in the shaft that could then be sleeved and cables plugged when lower shaft and drive unit are fixed in place in the centreboard. . This is intended for exploring confined non tidal rivers and canals over in France where I live, in areas where sailing the boat isn’t really an option. Normally, of course, I’ll be sailing or rowing. Thanks again for you replies!
Poignard
23 Jul 2005
South London
How about something like this?
Or this:
A side mounted electric outboard on a removable bracket could be used when required and stowed away out of sight when not in use
billskip
6 Sep 2001
Why not look at a flexible drive cable like can be operated by battery drill.
I think you will have to make your own system..but a flexible cable can be just pushed up the space.
Plum
6 Jun 2001
UK East Coast
Hi,
Puffin
something like this mounted on the rudder would be easier. 341.8£ 22% OFF|SUP paddle board surfboard, paddle board electric propeller fin underwater propeller| | - AliExpress
www.solocoastalsailing.co.uk
Nicholas Blyth
3 Nov 2022
Good morning Plum,
That looks like the perfect solution for me and it answers the drawbacks to my original idea that were rightly raised in other responses. I’ll go for this solution (never seen these before) and many thanks to all who helped me out on this!
Nicholas Blyth
3 Nov 2022
Hi Hermit,
Many thanks for the suggestion. Yes, this would be simpler and I’m impressed with the reviews of the product, but am attracted by the other solution as it will be less visible!
Poignard
23 Jul 2005
South London
Good morning Plum,
If you go for Plum's suggestion (Post #9), how are you going to pass it down through the 3.5cm centreboard slot? Or have you decided not to go with that idea?
Plum
6 Jun 2001
UK East Coast
My suggestion in post #9 was to mount (clamp or clip?) a drive pod on the rudder. It could be mounted on the side of the rudder and assuming it is a lifting rudder the drive would not ground in shallow water.
Www.solocoastalsailing.co.uk
