MJWB
My CAV filter has solid bowl not glass. At the bottom is a drain screw. That currently has what appears to be a copper washer which I assumed was supposed to help seal when the screw plug is tightened. I am not mechanically minded but learning.
In the last couple of years when I've changed the filter, refitted the drain screw and tightened it up there hasn't been any leak. I changed the filter and reassembled in December and now find there is a leak. I'm almost certain it is around the drain screw as I can't find deisel anywhere else on the unit. I note that the air bleed screw washer on the top of my unit also appears to be copper coloured.
These were what was in place when I got the boat in 2020 and I've re-used them as there is nothing in the seal kit to use.
Is this the correct washer on the drain screw and should it prevent leaks? It isn't now.
Should I replace it with something else more appropriate?
Many thanks.
Many thanks.
