Definitive list of windvane options?
Kelpie
15 May 2005
Afloat
There seems to be a huge range of different windvanes available; I keep coming across ones I had never heard of. So I reckon it could be useful to compile a list of all the various options, including out of production models that are readily available secondhand.
So here's the ones I've come across:
Ares
Hydrovane
Monitor
Wind pilot
Mr Vee
Hebridean
Neptune
Sea Feather
Navik (out of production)
Any more for the list?
temptress
15 Aug 2002
Gone Sailing -in Greece for a while
gbr195t.com
Ares
Hydrovane
Monitor
Wind pilot
Mr Vee
Hebridean
Neptune
Sea Feather
HP
Why bother with a wind vane these days.odern autopilots are extremely reliable, you can buy 3 for the cost of a wind vane and with the power charging systems on boats these days power is no longer an issue.
JumbleDuck
8 Aug 2013
SW Scotland
Sea Feather
I was about to say that Sea Feather was also out of production, but I have checked and they are back on the market again with new owners.
I met someone on a boat like mine doing a circumnavigation of the UK. Between Essex and Bangor NI (via Land's End) he had gone through three new tiller pilots. Windvanes are silent, reliable, consume no power and they are mesmerising to watch.
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
As well as agreeing wholeheartedly with Jumble's comments (esp "mesmerising"), please direct me to an electric system costing under £1000 which can reliably steer a 60-footer for months on end.
dave_gibsea
12 Feb 2002
SW London
I put a thread on a couple fop days ago re plans or a kit for wind-vane steering. I don't like relying on electronics either and I only have a small engine (with a small alternator) for charging. Also, I like the idea of the wind-vane. My research (so far) hasn't come up with one specifically designed for transom hung rudder although I understand the early ones were developed for this type. I guess these days most boats are well over 30ft and don't have transom hung rudders....
Minchsailor
2 Dec 2014
N of Ardnamurchan, winter South of Oban
...My research (so far) hasn't come up with one specifically designed for transom hung rudder although I understand the early ones were developed for this type. I guess these days most boats are well over 30ft and don't have transom hung rudders....
I have a Rustler 36 with a Hydrovane mounted off-centre. Works well, no problems on either tack (a previous owner took it around the world).
hrchivers
13 Nov 2008
I have a sea feather on Sandpiper (Sadler 29). It is fine with the transom-hung rudder, and a sensible weight for a small boat. https://www.youtube.com/watch?v=FubCRf4YOiM
steveeasy
12 Aug 2014
Haslar is another to add to the list. why bother, well far better to have a back up and the sense of achievement in using something that requires no electric is reason enough. Oh currently searching for spare parts for an SP2!!.
Steveeasy
Triassic
12 Dec 2014
SE UK
Dave, If I were you I would get the upper unit of the Scanmar AutoHelm https://www.scanmarinternational.com/auto-helm and hook it up to a trimtab on your transom hung rudder.
That might rather depend on the design of his transom hung rudder. For a trim tab design to work effectively the rudder needs to be balanced, and if it is you can't just add a trim tab to the trailing edge as this alters the balance...... In practice you need to cut the tab out of the existing area and this is a bit of a gamble unless you're really confident about what you are doing.
