jordanbasset
Because the saloon (main living/relaxing/dining area) isn't at deck level.
... As you can tell I quite like the Rustler but I am unlikely to end up buying one, preferring the stupid idea of building my own boat. Any thoughts welcome.
To paraphrase an old saying: 'there are those that build boats, and those that sail them.'
How long do you have, are you suggesting that you'd work on the new ship yourself or pay a builder, and would it be wood, metal or plastic?
Ooh! Sounds as if it might be very difficult to repair, in the event of damage. However, best of luck with your project.
Sure but by that definition half the boats marketed as DS are not.
I like to think of it as a saloon, with windows at a height so that seated people have a good view of what's happening around them, also having a helming position, but not just a wheelhouse. Mine has three steps down from the weather deck, and then two steps down into the galley and forward cabin, and equally two steps down into the aft cabin.
Within the saloon, the area on one side, with seating and table etc, has its sole raised higher than the other side which is largely taken up with wheel, console, access etc.
I have come to dislike the longstanding yacht designs where once down into the saloon, one could be anywhere, and can't see anything, but that's just personal preference.
Fair enough, but having built a strip planked, edge glued, and nailed, yacht in the past, I am very aware of the difficulty presented if you were unlucky enough to have significant damage. Good luck.
I will be using a profiled strip so it will be edge glued only, minimal or no nailing required. Did you put cold moulding over the top of the strip planks. The construction is quite different from the traditional strip plank canoes since the strip planking is essetially just a mould (with structural benefits) on which to place the cold moulding rather than creating a seperate mould that does not form part of the boat.
So, now we have some understanding of the terminology...
What do we think about a steering position? Is it best simply to control the autopilot from here or is a wheel better? A wheel takes up space and may affect the ability to cram in a proper nav table. However, a wheel feels nicer to use than a button or joystick.
