Cutless bearing/shaft question,slightly different
saltyrob
11 Apr 2004
Suffolk
Hi Folks,
Have established that shaft is worn. Rather than fork out for replacement, as watching pennies I am thinking of machining present 1 inch shaft to 25 mm and getting slightly smaller cutlass bearing. The machining would only be for the length of the P bracket housing the bearing, as we have a rope cutter fitted which is designed for an inch shaft and similar prop boss. Therefore would there be an issue sliding a bearing designed for a 25 mm shaft along the inch shaft and into the P bracket.
Hope this describes the situation
Many thanks
Rob
saltyrob
11 Apr 2004
Suffolk
Hi
Standard cutlass bearings are available with an outer shell of 4 inch x1.5 inch to suit P bracket for either a 25 mm or 1 inch shaft . So the bearing would fit in the P bracket and I guess the shell thickness or rubber lining is slighty larger to suit the smaller 25 mm shaft. Once the bearings is in the P bracket should be no problems ,but the bearing would have to slide from aft along the 1 shaft shaft into the P bracket and cannot reduce the size of shaft where rope cutter /prop fitted.
Hope that it explains a bit better
Many thanks
Rob
Tranona
10 Nov 2007
Hi Folks,
Many thanks
Rob
It will only work if you machine the entire length from in front of the P bracket to the taper. Then your rope cutter will not fit. Really no sensible option but a new shaft. Remember 25mm is smaller than 1" so you cannot slide a 25mm bearing down a 1" shaft.
SteveIOW
3 Oct 2008
Isle of Wight
Concur with Saltyrob that cutlass bearings for metric shaft (25mm) with imperial OD (eg 1.5" OD) are available. Speak to T. Norris Ltd re their Part No W25I.
Hope this helps.
Steve
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Whatever you do you have to take the shaft out, which is hardest part.
What are you going to do with the cutter?
- Ditch it
- Shim and bodge it
- Buy a new one, which will cost more than a shaft!
Who would want to buy the boat from you with a non standard shaft?
Do it right, get a new shaft, you will have to at some stage of the game.
PS Did you read this thread?
http://www.ybw.com/forums/showthread.php?387920-worn-propeller-shaft-at-cutless-bearing
wee_niall
11 Mar 2003
Tayport, Fife
does sound like your in a similar position to me, although if you're going from 1" to 25mm you're only reducing the shaft by 0.4mm and if the advice on my thread is right about the tollerance being 0.6mm it's probably not worth the effort....my shaft is worn by over 1mm which is why i kinda need to do something :D
