Elessar
Busy at the moment so I had the legs serviced rather than doing it myself. I needed new trim senders which is a pain on mercs, as well as bellows etc. I was also fitting new depth and speed transducers and polishing up to the gunwale, all to be done in the 48 hours she was out of the water.
Plan was to go in last Wednesday, take a trip to the IOW with some pals to test her before she did a YM exam at the weekend.
Anyway, into the water, check for leaks - leaking fast. Back out, leg off, transom shield dismantled to reseat the seal on the trim sender cable. Glad that bit wasn't me........
Launch again Thursday lunchtime. Seemed fine, checked all pumps etc. Cleaned boat and took her back to shamrock by about 9pm so decided to stay overnight.
Glad I did. Next morning she was down about 9" at the stern. Fortunately I realised and pumped her out just before it got to the level of expensive in engine damage terms or flippin expensive in sinking terms.
Basically, the steering arm on the transom shield has worn and is letting in water. The service shouldn't have touched the steering arm but I guess taking the shield apart has exposed an underlying fault.
But my mistake was that I checked the pump with the on switch not with the float switch. The cable to the float switch had been pulled out of the connector.
I'm now back out figuring out how to completely remove the transom shields without taking the engines out. I hope it can be done as I have 2 weeks to get her all fixed before her next booking, taking the engines out means dismantling quite lot of boat.
The port steering arm has about half on inch of vertical movement so it certainly is nackered.
Boats
Boats
