Corvette 32 - A tale of one owner’s upgrade
superheat6k
10 Jan 2012
South Coast
Following interest in a thread explaining my adventure restoring my recently acquired Corvette, I felt a chapter style tale might appeal.
Chapter 1 - The boat
The Corvette 32 is a small Trader / Trawler style motor yacht with the distinct advantage that unlike most trawlers this one can plane, but is equally happy pootling along in displacement mode.
I first came across the Corvette whilst I owned my first power boat, Mobby, a Dutch Barge style centre cockpit boat with moderate accommodation, but a bit too small for a growing family. The Corvette has a decent size aft cabin with ensuite, central saloon / wheelhouse, and a dual forward cabin with its own head midships. A veritable tardis.
At 32’ 6” LOA they are a roomy 13’ beam, and are offer wide side decks that are level right around the boat, and a decent 1” stainless ‘fence’ that surrounds the entire boat, so very safe for kids and dogs.
The accommodation doesn’t end there - outside is a raised ‘poop’ deck above the aft cabin, with two steps to a roomy flybridge, with more seating, so a very sociable boat for outdoor entertaining and living. They were built to a reasonable standard, with teak decks as standard, and an increasingly powerful range of engines was provided.
The thing I have noticed a common theme with Corvettes is that once bought they stay in an owners possession for a long time, and this leads to an unusual number that are for sale being found in a somewhat neglected condition. I have figured out this is due to the sad fact that many of the owners will gradually become unable to maintain and use their boat, but they realisation of this takes several years before the “… I should be OK to take the boat out in a couple of months …” eventually passes, as the kids and grandkids bemoan the cost keeping the boat languishing on a forgotten mooring somewhere eating up the inheritance. Eventually these old boys sadly have to sell. This was the case for each of the four I viewed in my recent hunt, and was also the case with the very sad example that led to me purchasing my Turbo 36 as a consolation prize in 2011.
Of note for those just back from SIBS is that Corvette name and moulds are now owned by Fleming, makers of the fabulous Superyacht on display next to the Nordhavn 65.
I will follow up shortly with my initial learning curve with Coolavin 2.
For those interested in knowing more of the Corvette 32 there is an owners group formed on YBW that is becoming more active with some 30 or so members. A read here is also of possible interest …
https://en.wikipedia.org/wiki/Corvette_Motoryacht
I really like the C32 but Ive aften wondered why they all sit low at the bow.
Looks a bit odd to me
The very first designs had engines in what is now the rear cabin with outdrives, but were only about 90 HP. Also the fwd / midships section of the bottom is a half run dome, almost unique shape. I suspect that the bow down appearance is partially due to both these issues, where the weight of the larger engines is now concentrated just aft of midships, and the inverted dome makes the bow rise at semi displacement speed.
Others have commented that they ride bow high.
If you passing by Bursledon there is one out of the water there - the underside is fairly unique, but seems to work very well. We found she hardly rolls at all, where the wide turn of the bilge sits outboard of the deeper section acting as a massive stabiliser.
Funnily enough I've just been in Drivers Wharf and there's one ashore, I noticed the hull shape, I didn't know they are like that, there was a boat in Freebody's yard at Hurley, ancient wooden thing, with a very similar hull. Think its prolly been chopped up.
Interesting thread about an interesting boat, I look forward to seeing the the story unfold. Always liked the look of Corvettes and used to see new ones at the yard in Reedham before they sadly closed. As already said the hull shape is very unusual but it works. Makes you wonder why other builders haven't adopted it.
a month or so ago we were out in the Solent coming up the western side towards Calshot and it was blowing a bit and up to that point we had only seen 2 other boats out, both raggies but not a single mobo, (in fact it was a bit too bumpy even for me to get my camera out), but ahead I saw a plume of white water with a boat just about visible every now and again. When we got a bit closer out of the spray appeared a Corvette, it looked great.
Always been a Corvette fan, until recently thought it might be a boat I would end up with. I am sure you will enjoy.
It seems to be an exceptionally efficient hull: not bad for a 7 ton boat with twin 100hp!
>'The engines favoured by the original builders were twin 106 hp Volvo Penta D32s, linked to sterndrives, and 105 hp Mercedes-Benz OM352s, with V-drives, top speed being about 16 knots in each case. This configuration generally required more use of the trim tabs to travel at the optimum angle.
interested to read this thread as I have its bigger sort of relation , the Searanger 48. The hull for the Searanger was based on a Corvette and stretched a bit. Fantastic sea boat and unbelievable in a beam sea so guess the Corvette is the same ?
Chapter 2 Old Man Syndrome - BEWARE
A private conversation on here with a potential buyer wanting some pricing advice for his intended purchase sparked a phrase that was clearly evident in my recent search.
All four of the Corvettes I viewed were suffering from neglect the result of the owners getting too old to properly service their boats. Indeed the one I bought had every window stuck hard closed due to ~ 2" of moss filling the entire gap between the base of the sliding panes and the condensate trap plate and right along the base of each sliding window.
I would suggest that such moss would take at least 2-3 years to grow once sufficient dust has settled into the gap to provide something for the moss to seed into and feed upon, so a further 2-3 years for this to gather. That's ~ 5 years neglect.
I daresay that prior to this the owner's health was gradually failing, and he was putting off the tasks he would once cursed others for not keeping abreast of.
"... But don't worry ..." he thinks to himself "... later next month I'll get down to boat and we will be out sailing in no time...".
Problem is next month, like tomorrow, never comes.
In the back of his mind nagging away like an old fish wife is the reality that he cannot accept, so he carries on paying the berthing fees, insurance, even professional maintenance on the engines (in some cases anyway !).
Then after a few years the fish wife is replaced by his own wife, and of course the kids, who see their inheritance being frittered away. Eventually he is forced to realise his boating days are over.
Reality sets in save of course he forgets all about the neglect that is now seriously affecting his price and joy, (after all when he last saw it the problems were not nearly advanced as they are now), and he sets out a ridiculous price, so there the boat sits for another 2 years languishing on some brokers books (not allowed to suggest on here boats might be overpriced or presented like a corporation bus shelter !).
One of the Corvettes I looked at had a massive pond formed in a dip in the flybridge tonneau. So I unclipped the tonneau clips to view the instruments etc. The water that drained out was completely green, with around 6 largish limpet shells for good measure. How often does a shite-hawk lunch on your boat and leave his wrapping behind - never happened on any boat I have owned, so perhaps at least 2-3 years for a seagull to have at least 6 lunch parties, showing me clearly just how often this boat had been viewed.
Mind you the one with shite without the hawk in the loo took the biscuit !
I have assessed that Old Man Syndrome is a wasting disease that likely takes 5 years to set in, and once established will afflict sufferers for at least a further 5 years before he realises.
That means I reckon I am good for at least 10 before it starts to affect me, but lets see !
How many of you are already suffering ?
I bet none have plans in place how to deal with it when (not if) it does set in.
nice,
SH, weather's been shite for the last two days, p1ssing down like crazy (probably all the water that should have given us over the last 4m...) and your writting (albeit very true) is not cheering me up at all.
How about a decent 2A chapter with real work on the corvette and lots of pics?
cheers
V.
Well that's a worry... ! I'm 60. I hope to get at least another 10 years before I succumb, so when should I start my exit planning? :) I'd hate to think my kids or SWMBO having to deal with a sad and tired neglected family member. To say nothing of the boat.
