GetItDone
Hi all,
I've been having a mare with my little Volvo Penta mb2a/50s which is basically a Honda BF 75 7.5hp on a sail drive. We had an engine failure, and upon stripping the power head the corrosion from the salt has eaten through chunks of water jacket in the alu block & head. I've got 4 spare PH's and one of them is the exact same.
Given I'm going to rebuild the whole thing, I'm not keen to repeat this in a few years because the same issue has occurred. I obviously don't know if previous owners flushed properly etc. but whilst I've got everything out and I've got an opportunity to do something about it I am sorely tempted.
My thoughts are to use a raw water to closed loop heat exchanger from another setup, though I haven't yet found one suitable that isn't new and rather expensive. I've also read about people using heat exchanges from old boilers, but I don't know how I feel about this with regards to salt and reliability.
I think it would be fairly simple to plumb it all in with a pressurised header tank, heat exchanger, 12v electric water pump for the closed loop, and then running the raw water through the existing raw water pump & exhaust.
Removing the compacted salt from the water jackets only to find holes in them is not something I'd like to repeat
Many thanks in advance for any advice.
