RAI
Why is there not a decent 12V DC plug and socket? Using a cigar lighter socket is ridiculous.
I have some through deck sockets that use thick and thin pins, so there is only one way round for the plugs. I chose to wire fat = positive. Maybe it should be the other way? However these are a bit bulky for internal use. I am pondering the virtues of using telephone jacks. The question is driven by a cooler box that draws 5 amperes and cooks its cigar lighter plug.Which way round should you wire a 2 pin dri-plug?
I'd rather not water and leccy don't go well together. I am currently revising for my Nigel Calder exam.Look up "flemings right hand rule" for alternators. Think of the plumbing in your house for wiring.
Does this require jeans?You can see it if you bend over.
But... I still don't understand why the heck I should care?
I can never quite get my head around prop-walk when in reverse.
You may well skip all the calculations and button pushing, in practice what is most important is to have a rough idea of the magnitude of the difference between the two.
Suppose you are sailing downwind at 7kt, full sails, you feel a nice breeze say 15-20kt (apparent as wikipedia instructs).
Then you want to turn by about 90°-120°-180° around that cape at the end of an island to head for a sheltered anchorage in the lee of the island.
Once you get to the cape (even without local effects) and begin turning to beat towards the anchorage, the apparent transforms into 25/30kt while you are with full sails...
I suppose it's one of the reasons one sees so many engines started at that point![]()
Main use of true wind is when motoring due to lack of breeze, but hoping it will fill in enough to be able to sail. The apparent wind from moving forward keeps tempting you into thinking that you'd be able to sail; the true wind display tells you whether there really is.
Personally I wish I could set my ST60 to display apparent wind direction with the dial, but true wind speed in the LCD window. I rarely care about the true wind direction or the apparent wind speed; without this mode I'm always flicking back and forth.
Can't speak for other boats but the old Royal Yacht had one in the engine room. Purely decorative!Does that mean Apparent Wind, is a red bus?
I get how an instrument measures apparent wind but how on earth does it know true wind without some nifty sog calcs?
I can only imagine I'm in the company of emeritus mathematicians - 156 posts and no-one's said the dreaded word......astro
Here's the challenge - explain astro in the same succinct manner that allowed me to understand lee bow.
Re true and apparent, it's my understanding that when beating the wind moves forward so you have to trim the sails accordingly. I do find myself checking the ST60 as SWMBON switches to true. Mind you she always seems to get another knot out of the boat![]()
Pretty sure they use speed through the water and heading rather than SOG and COG.Exactly how it works Using SOG and Track, or STW if no GPS signal.
It is not "astro"...it is Celestial Navigation...if you don't mind.
"Astro" is seagoing slang.![]()
