Uricanejack
Does this require jeans?
Chapps?
My burgee and bits of ribbon on the shrouds, are firmly locked on to apparent wind.![]()
Astro in a nut-shell!
At any particular moment, any celestial body (Sun, Moon, planet, star) is directly over a specific point (the nadir point) on the Earth's surface. If you know this point (which requires an ephemeris and time), and measure the elevation of the object using a sextant, in principle you know that you're on a circle centred on that point, whose radius is 90 - the measured elevation in degrees. You can use that circle (which because you know roughly where you are from DR, you can regard as a line perpendicular to the direction of the nadir point) as a position line in exactly the same way as any other position line.
Of course, there are a lot of other things to take into account, such as the effects of your height above sea-level, atmospheric refraction and (for the Moon) parallax errors, but in principle it really is as simple as that. Of course, the mathematics of spherical trigonometry is a bit tricky, but people have kindly worked out rule based methods of side-stepping that bit.
Why is there not a decent 12V DC plug and socket? Using a cigar lighter socket is ridiculous.
The sound signals are actualy based on the international code of signals, single letter signal flag meanings. and morse code.
Signal flag Echo or E single letter meaning, I am aletering course to starboard. Morse . , dot or 1 short blast.
Signal flag India or I single letter meaning, I am altering course to port Morse .. , Dot Dot or 2 short blasts.
Signal flag Sierra or S single letter meaning, I am using astern propulsion, ... , Dot Dot Dot or 3 shorts blasts.
Signal Flag Hotel or H single letter meaning I have a Pilot on Board, .... , Dot Dot Dot Dot or 4 short blasts
Signal Flag Tango or T single letter meaning, underway making way. -, Dash or 1 long blast.
Signal Flag Mike or M single letter meaning, Underway Not making Way, -- , Dash Dash or Two long blasts.
Signal flag Oscar or O single letter meaning, Man over board, --- , Dash Dash Dash. or 3 Long Blasts.
Signal Flag No5 guess the meaning No Its Not actualy get the F!#$ out the way % short Blasts.
Don't worry I'm not so good at sail trim
I started this reply to ask you to explain this, then it suddenly made sense. Thank you.... in principle you know that you're on a circle centred on that point, whose radius is 90 - the measured elevation in degrees...
You learn something new every day, or two things today. I always assumed that starboard was one blast because it was "senior", and therefore first.The sound signals are actualy based on the international code of signals, single letter signal flag meanings. and morse code...
True wind is what you feel on a boat at sea that is not moving, but is still subject to tides and currents and so is not stationary geographically.
Actually I am going to be a smartypants and admit I knew that as I also know morse code very well and was therefore aware of the relationships you describe - but that's another story.
You've missed out "D" for "difficult" One long and two short, which also fits the pattern. I sometimes chat to YM candidates about the very logic that we are discussing here and the relationship of the sound signals to morse code.
However I would still argue that there's a bit of chicken and egg about some of the signals and I still think that there's some logic to the shortest code letter "E" being one short (and chosen as commonest letter in normal English), but also the more frequently used of the sound signals indicating which way you are turning.
I have no problem with the concepts of true and apparent wind but now you've lost me. The boat isn't moving but is not stationary?
Cunningham: a means of flattening the mainsail by pulling down on the luff of the sail. (Instinct says that halyard tension has already sorted out luff tension but cunningham tension works for counter intuitive reasons.
Vang: just another word for the kicking strap. Sometimes ascribed to be an Americanism. A means of controlling the twist in the mainsail.
I think I saw some about 30 years ago awfull stuff, fairy liquid works.
D -.. I am manouvering with difficulty, keep clearI was taught D (-..) = Keep Clear. (or danger, keep clear).
Brilliant! Thank you. Has much unmuddled me on the topic.
True wind is what you feel on a boat at sea that is not moving, but is still subject to tides and currents and so is not stationary geographically...
That is why you have to be extra careful when sailing downwind. A few weeks ago whilst at anchor I read an old yachtie mag which had an article written by an accomplished yachtsman (cannot remember name) about three occasions when he was caught out with too much sail up when running downwind. The next morning we set off south down the Sound of Mull on a cracking broad reach. Then the wind came further aft and increased which I did not notice until we had to gybe to avoid the ferry at Loch Aline. A bit hairy and the main came down shortly afterwards and we ended up surfing under genny alone.You may well skip all the calculations and button pushing, in practice what is most important is to have a rough idea of the magnitude of the difference between the two.
Suppose you are sailing downwind at 7kt, full sails, you feel a nice breeze say 15-20kt (apparent as wikipedia instructs).
Then you want to turn by about 90°-120°-180° around that cape at the end of an island to head for a sheltered anchorage in the lee of the island.
Once you get to the cape (even without local effects) and begin turning to beat towards the anchorage, the apparent transforms into 25/30kt while you are with full sails...
I suppose it's one of the reasons one sees so many engines started at that point![]()
I'm told this works:Here's a sailing question for bargain-end yachtsmen...does any company anywhere still produce and sell salt-water soap?
