JumbleDuck
And your authority for saying this is ... ?IMO this subject is far too dangerous to be discussed on a forum where to be honest not everyone knows what they are talking about.
True, but you can get a 415v hazard from multiple 240v installations if they happen to be different phases. As you know, I know you know, and you have said before. But we do have some rather inattentive readers in the thread ...How do you get a 415v hazard from a 240v installation, you cannot.
In the days - long ago - when I did some theatre lighting, there was a minimum separation between phases in theatres. Six feet?Post#6 from superheat, where he correctly states "The only safe way to have two separate supplies on any boat is to keep the entire supplies and distribution systems on board completely separate. Opposing phases of the same supply can never be paralleled. " Which is exactly what i've been saying all along.
FWIW page 3 here https://electrical.theiet.org/media/1987/wiring-matters-may-18.pdfIn the days - long ago - when I did some theatre lighting, there was a minimum separation between phases in theatres. Six feet?
That was covered further up the thread, and considered by the OP.Its been an "interesting" thread for me to read as I have worked with three phase supplies up to 800amps and motors for the last 25 years
When I semi retired I didn't have the luxury of a three phase supply in my home workshop which slightly hindered my work until I fitted a unit similar to this;
4KW 8.5A 220V VFD INVERTER SINGLE PHASE VARIABLE FREQUENCY DRIVE NEW | eBay
Worked reasonably well and enabled me to service chain hoists at home until I finally retired last year.
So with a bit of jiggery pokery it is possible to get a three phase supply from a single phase![]()
Forgive me for missing it amongst all the other stuff!That was covered further up the thread, and considered by the OP.
It's been one of those threads....Forgive me for missing it amongst all the other stuff!
Apologies if it looks like i'm picking this apart ( i suppose i am, no offence intended), but it does look very much like you haven't read what's been said previously.
I'm not aware of anything that can do this, although i'm not an industrial electrician. It would be a pointless exercise anyway, the only thin on the boat that is 3 phase is the grey water pump, so if such a device existed you'd be creating 3 phase, only to split it back into separate single phase systems one onboard (except for one pump)
Given that the boat is 65 feet and has a long list of electrical equipment, i single 240v supply would be extremely limiting.
Can't argue with this, but it's been suggested several times and the OP doesn't want to change the pump.
Permanently restricting a 65 foot boat, fully loaded with 240v equipment isn't a great idea, IMO. Not only is it too restrictive, it makes the existing 3 phase genset redundant. Post #64 details how to supply the boat with two 16a supplies, when available, and still keep the option of using the genset at sea, when no shore power is available, or when requirements exceed single 16a supply. It also allows the OP to continue using his 3 phase pump. Finally, it allows him to use a 3 phase supply from the marina, when available.
How is a 3 phase genset going to work, now that you've got him to connect all onboard services to a single system ? You also had him change his pump to single phase, so that won't run from the genset. But, more importantly, he already has a 3 phase genset, that powers all of his 240v equipment by splitting the phases, whilst running the 3 phase pump. This is the main reason i asked if you had read the thread![]()
In #69 he refers to " the generator"I don't see the OP state or acknowledge that he already has a 3 Phase gen Set, which post is that in ? I see where you deduce that he has. Maybe the OP would clarify this point and specify the KVA of the set.
If he already has a 3 phase gen set which can run the boat , why bother searching around pontoons looking for 3 separate 230V supplies which he will have to ensure are from the 3 separate phases,-how do you do that anyway ! Gets fairly complicated if you need to add credit to 3 meters or buy specific credit cards for each one !
And you misread what I suggested.
I suggested that if the total load could be managed to 16A then combine all 230V equipment onto a single shore 230V supply .
If the load is greater then go for a 3 phase Gen set and leave the wiring as is.
Kinsale 373
Interesting, thanks. I think the theatre rule was additional (or a codified one along the same lines) because the electrical demands can be enormous - 200 x 500W lamps would be a small setup - and it wasn't unknown for portable dimmer boxes to use multiple sockets to feed them. Even without such horrors it would probably have been a bad idea to have alternate lamps along a batten running on different phases.
The boat I'm looking at (Bayliner 285) has 2 shore power lines, one for the domestic appliances and a separate one for the air conditioning and it is a only a little 28ft speed boatFor those who think you cannot put more than one 16a supply on a boat, have a read of the mobo forum, where such installations are common place. The link below has some interesting posts in it, particularly if you ignore the argument about unplugging someone elses shore power
A couple of noteworthy posts from jfm at the start of the thread.
I also noticed some comments about using 32a marina sockets with splitter cables (not to be confused with the LBOK), i'd forgotten about this option. This could be used by the OP if he arrives at a marina that only has a spare 32a supply, he plugs the Y cable into the 32a marina outlet and the two 16a plugs into his 16a sockets on the boat (assuming he has it wired how i suggested). So he's got a pretty flexible system, he can connect to 3 phase if available, he can connect to 32a if available (on busy days 32a may well be more available than two 16a), or he can connect to one or two 16a outlets.
2 shore power cables on a Fairline why?
Was a problem with my fleet of trucks and vans, most gensets are a nominal 230V @60Hz and a lot of the equipment we used took the mains frequency for reference, if you dropped the frequency to 50Hz then the voltage was too low and you would get a brown out in the equipment, as happened after a service.Yes, but it was a fiddle. Although EU standard is nominally 230V, there is a sufficiently large tolerance band (+/- 5%, from memory) to allow the UK to continue on 240V and furriners to continue on 220V, as before. Last time I measured mains voltage here, a couple of weeks ago, my meter said 239.5V
I can't understand why it's still going on!A very concerning thread with what is simply dangerous nonsense being talked about by many contributors so far.
Well I'm retired now, I make no claim to be any sort of expert on anything, my electrical knowledge, such as it is, is only what I've picked up during many years working as a plant maintenance engineer. Designing, building, installing and maintaining control systems for processing lines, both AC and DC, used for the production of plastic raw materials.Remind us all, what do you do for a living ?
