DaveS
Charging electric outboard battery
There are several ways to go about it, but here's what I do. I've had an electric outboard for a few years and, accepting its limitations, find it Ok.
My approach for the battery was to get an additional 85 Ah "leisure" battery and put it in a plastic box fitted with a tape "basket" to allow easy slinging. This normally lives in a cockpit locker (strapped down) and is connected to a polarised socket. On the dinghy the outboard plugs into this socket; on the boat another plug goes into it. The cable from this plug is connected via a circuit breaker at each end to the 110 Ah domestic battery so that in effect the domestic battery is now bigger, being a bank of two, one of which can be easily detached to power the dinghy.
After using it for a longish run on the dinghy I generally don't close the connecting breakers until the main domestic battery has taken a good charge. I don't have wind or solar generation, but do have shore power, but the principle is the same.
Dear All,
Having recently bought an electric outboard, I am now looking into ways of recharging the battery for the outboard. As one of the reasons I got an electric outboard was to avoid having additional fuels on board, I don't want to consider small generators, though that is one obvious (and cheap) solution. Ideally, I want to be able to charge the battery from the 12 volt cigarette lighter outlet (obviously, with the engine running). Equally ideally, I would like to be able to monitor the state of charge of the battery (a 70 Ah leisure type battery).
I don't use shore power. We have a Rutland 913 charging the two main batteries, but the regulator (HRDi) is only suitable for use with two batteries.
While we are away from the boat, I have a small solar panel that should trickle charge the battery, but this is a low amperage job that will take many days to replace the power used in a short outing with the outboard.
Suggestions welcome!
