AntarcticPilot
Dear All,
Having recently bought an electric outboard, I am now looking into ways of recharging the battery for the outboard. As one of the reasons I got an electric outboard was to avoid having additional fuels on board, I don't want to consider small generators, though that is one obvious (and cheap) solution. Ideally, I want to be able to charge the battery from the 12 volt cigarette lighter outlet (obviously, with the engine running). Equally ideally, I would like to be able to monitor the state of charge of the battery (a 70 Ah leisure type battery).
I don't use shore power. We have a Rutland 913 charging the two main batteries, but the regulator (HRDi) is only suitable for use with two batteries.
While we are away from the boat, I have a small solar panel that should trickle charge the battery, but this is a low amperage job that will take many days to replace the power used in a short outing with the outboard.
Suggestions welcome!
