SimonNZ
Active Member
Hi all
In our Beneteau anchor locker, a previous owner had screwed a quarter-piece of PVC pipe horizontally across the front of the 'slot', shown as a red line in this image.
It got broken off but when we got the boat, the lower chain ran over the TOP of the PVC before falling into the locker. Chain piled further forward, and more chain makes contact with the gypsy.
I experimented without the PVC before it broke; no problem with the piling but as there's a decent distance from top of gypsy to bow roller, after a few seconds bounce is introduced which slips the chain on the gypsy, so I put it back to gain the extra purchase.
I'm not sure what the configuration is supposed to be. There's was a hole for the spill but that seems to be ground off (unlike the pawl, looks like it caught under speed and sheared out of the casing). The original existence of that hole suggests there's only supposed to be a quarter-turn contact on the gypsy but perhaps that varies from boat to boat.
Also, the lower chain tends to grab when the anchor is being pulled up, mostly due to tie-wraps (sometimes multiple) that someone added as markers. My intention is to remove those, take all the chain out and paint new markers - but I see they're still a really popular option as markers, easy to see and replace, so I'm surprised they are able to cause such an issue. If you're not really careful, the falling chain comes back up under the upper, leading to lots of jamming, messing with the clutch, hitting the chain with things and swearing.
It seems the best approach would be to fit some sort of idler at the front of that slot, or even just a rod of stainless properly mounted, to get things back to how they were - but it doesn't really 'feel' right to me especially since the falling chain can drift from left to right depending on the piling.
Any advice or comparison with your own windlasses and experience would be appreciated; how much bounce do you get between gypsy and roller, do you get the same 'stick' when pulling in, how much chain contacts your gypsy and how do you prevent slippage?
I'm aware I should measure the chain and check the gypsy is the correct size too. I have not done that yet, need to learn how!
As a side note, I'm fascinated by the missing cleat. The remaining step is very clean, almost as if it was removed at the factory or never forged. Is this common?
cheers!
cheers!
