AnthonyH
This thread has got a bit weird. IMHO
Good morning Mudisox,
Weird, how so?, Please explain.
Cheers,
Tony
PS: Pardon my ignorance, what does IMHO mean?
I saw a catalac a few months ago approaching portsmouth harbour.
It had an outboard of a fair size mounted on each hull and was motoring a good 18 knts !
In My Humble OpinionGood morning Mudisox,
Cheers,
Tony
Hi There AntarticPilot,In My Humble Opinion
Really interesting Tony, when is the maiden voyage? May I invite you to share experiences on facebook page Catalac catamarans? I myself am in the process of building a bow-e motor construction functioning as bow thruster as well as extra propulsion unit , pivoting it towards the wind aiming for better windward performance without having the noisy diesels to stand by.
Hi Tony. It is a 2 kW motor 24 V from Caroute-outdoor. It came in last week from China. It will swing from an extended platform that I create by adding a 2.75 m long carbon tube over the outerpoints over the bows. When not in use it will hinge back under the bottom of the boat, pulled back by a line from the aft of he boat. When to be put in use, the line will be released and the motor swings forward. It is side ways supported by two diagonal M10 threaded rods in a spanner. In forward direction, it is kept in postion by its thrust. For backward fixation I wil make some king of brace that is also retractable. The motor can pivot around the vertical axis over about 135 degrees. Startposition is 90 degrees wrt the boat 's longitual axis. It is then of the smallest dimensions when swung under the bottom. In this downward position it functions as a bowthruster with forward/backward thrust as well as power as variables. (Max thrust about 70 kgs according to specs.) Then, from this positon the motor can pivot 135 degrees. So maximum or key positions: 45 degrees to port, straight forward, 45 degrees to starboard,90 degrees to starboard,(which is the folding position also). I will use a outboard steering device for pivotting it. Controlling this can be via an extra wheel but that is crampy as well as weird in the cockpit so I am considering a 24 V dc motor, remote controlled via a H bridge. Coupled to the steeringhouse of the unit. I added a little sketch, will work on something more decent though. For the battery, I ordered24 LiFePO4 60 Ah pouches from GWL in Czech Republic and a "Overkill BMS" from USA. As said motor came from China. (Mind all those tariffs.....) So the batterypack will be 4.6 kWh and with a degree of discharge of about 60 % that will make 2,8 kWh. I expect usage of about 25 - 50 % so 2.8 hrs or longer?? I might also add a carbon fiber rack with two 250 W solar panels later when it works out. It is rather costly, expect it to be around 3500 - 4000 € so hope it works but OK, it makes fun in these times of Covid. Some motivations: I changed from flat rudders to profiled and experienced that spinning around and motoring backwards became more difficult. Profiled rudders work perfect when going forward but backwards is more of an issue. The marine box I am hiring is crampy and often wit a lot of wind. Getting in and out is an annoying thing. My wife hates it so this provided a good reason for the investHi J. When? Of course, this is the big question? I have set myself to work on a huge project. I have the windows and the new exterior mouldings made and fitted and also two lovely looking refurbed 14 HP engines sitting in the garage, and I also have the interior stripped out, and that’s about it so far!
So if I was dreaming say 2 years!!
I will say that if I hadn’t had the boat parked next to the house, I don’t think I would be anywhere as near as I am now.
Your E thruster unit sounds an interesting project although I can’t quite envisage its design? with its pivoting multi directional thrust ?? and/or how and how long you would need power it?
Well good luck with it.
Cheers,
Tony
PS: Share more if you wish, I won’t patent it!
jnjanversteegAnyway, I am very interested in your experiences with the LAR keels. Can you share some calculations about windforces, sail area/reefing etc? How did you decide on dimensions of the keels? I know of Lars Ouddrup who provided simple rules of design from the time that computer design was not common. He took as an example a 9M in a publication for the Dutch Catamaran and Trimaran club and designed daggerboards. The maximum surface ( from the view of boat stability) is some 1.3 m2 per side and they could create forces on the hull up to ( I recall) several tonnes under unfavorable conditions. I have this article somewhere so can share more details if you are interested.
I will also ask further about the swing keel that was applied under an 8 m as shared recently on the Catalac facebook site.
Then I saw somewhere on a forum, a photo of a dried out 9 m with also a bow motor but not at a detailed level. Cannot find it anymore, should have saved at the time....So if somebody could help...
ok, will look for it when at home and translate it as it was in Dutch. Janjnjanversteeg
I'm interested in those Lar calculations and the article if you can find it.
