Cat A ocean standard need full revision
Interesting reply by Tranona as the regulations have been updated in 2020 for hull windows. However the definition of watertightness still fails in respect of the impact of waves or hull flexing. These should require stress testing as a waterproof window is defined as one that can sustain constant immersion, which is far less bonding strength requirement than repeated impact of waves along with hull movement.
Some google trawled evidence to back up Tranona's points. From the insurance arm of BoatU.S.
1. For every boat that sinks under way, four sink on their moorings/berth.
2. Biggest single cause of their reported sinkings under way are through hulls or hoses from through hulls failing.
3. Then comes hitting an enderwater object rocky shoal etc
4. Hitting floating objects such as logs
5. Rough weather knockdown/downflooding comes last.
No mention of windows or keels
The windows, being bonded from the outside, will be better when submerged since the water pressure will press against the window.
The adhesives use have a strength of over 10KG/cm2 when properly applied and maintained. This is more than sufficient for the application. Engineers know that, regulators know that, forumites continue to speculate
The yacht that lost its large over sized pilothouse windows in the New Zealand storm were blown out front the inside by the pressure of hull flexing.
What has the boat building industry or the ISO standard done to implement measures to stop this happening on other boats built with bonded windows?
But those aren’t windows below the waterline so an entirely different scenario. If you lump these all together it just sounds like the problem is modern design.
Edit: that Bavaria didn’t even have windows in the hull.
Keels falling off is a good headline maker, like a capsizing multihull. Both extremely rare, but people are irrationally fearful of them.
Such incidents perhaps also tend to result in spectacular/significant, probably "reportable " accidents. Fatalities not unusual.
Eg Plenty about keel loss in MAIB references.
Little about bonded in window loss, SO FAR... AFAIK!
My UK built, RCD Cat C boat with bonded in cabin windows, failed at about 10 years old...
No frits, therfore perhaps improperly designed/installed? Not a significant reportable incident.
See Nov 23 posts on here...How Safe are Windows in the Hull
There is an order of risk. Bonded in windows in the hull would be perceived as a higher risk than bonded in windows from a deck saloon.
As I pointed out in my earlier post. Friends deck saloon windows fell out. This isn't an isolated case, although the level of failure of our friends was a little alarming. I am sure the high temperatures of leaving such a boat on the hard in Antigua every summer and the UV were instrumental in their failure.
Lagoon catamarans have the curved front windows fail. I know two of them that have had this happen. None of these bonded window failure that I know about first hand were on hulls. Both windows that failed were curved so its possible that the curved aspect contributed to the failure.
The Lagoon 62 had a professional skipper and was maintained to a high standard. The window failed without warning.
My friends Lagoon 38 was old but had been in the Caribbean for a number of years. It popped out whilst sailing.
It’s also very far from common, even less so in boats properly maintained or within the expected life of the adhesive.
How old was your friend’s boat and what maintenance had they or previous owners done to the windows? I’m not saying mechanically fixed windows aren’t better, but I do think bonded windows are adequate. After all, the grid in your friend’s boat is bonded to the hull too with no mechanical fixings.
Wrt A+ categories or similar...
Significant vessels, including yachts, have long been built to INDEPENDENT Classification Society standards, not those chosen by the builder. Most ships are.
Eg see.
Class Notations for Yachts
Craft built from Class approved materials, using Class approved systems of build, to Class approved designs. Often under direct supervision and checking by surveyors from the classification society (employed by the new craft owner, if they are wise).
There may be parallel, or even additional checks made by Flag state authorities (MCA in the UK), especially in the case significant passenger vessels.
= A+ standard?
These are entirely different (and far superior) systems of design, build, approvals and test from the ISO and RCD based categorisation (and the sometimes rather random requirements of the World Sailing categorisation) ...which are rather more akin to marking one's own homework...imho...
The problem seems to me to be that the current rates of advances in technical offerings by manufacturers/builders outpace the capabilities of the authorities to properly assess or approve them. "Novel applications" are increasingly sold before being properly developed. And are too often of dubious manufacture.
Eg large complex composite structures, podded propulsor drives etc...MCAs latest missive on battery technologies is perhaps one such example that is regularly debated here?
The sea balconies now being fitted to the forward shoulders of some giant MoBos make me cringe...but presumably someone is "approving " them?
There is often no time to gain experience/train (buyers, installers or operators) or adequately bed-in such technologies.
Bonded in windows (hull windows in particular) in the humble yachts that I experience personally seem to fall into this category, imho...
...as a retired Engineer and Regulator.
However, none of us are here to write an academic paper, forums are great places for speculating..or "brain storming" as it might be called in some quarters these days?😉
It seems to me amazing that expensive and complicated items such as boats do not come with a rigorous maintenance schedule.
As many have observed it isn’t particularly helpful to a buyer of a 10 y/o boat to know that, when it was built, it met a specific set of standards without also knowing what maintenance was required over that 10 years to keep it at those standards and whether such maintenance was carried out.
Buying an aircraft the first things you’d look at would be the operational hours, maintenance requirements and maintenance log.
Cars have to pass MoT tests, so much of the work is done for you. (Plus with a servicing schedule - which can be cross checked for compliance)
Boats, on the other hand, sell on a row-away factor and maybe a few receipts that show the engine oil was changed and the topsides given a quick polish 5 minutes before the advertisement was written.
They’ve been used for decades, they’re in no way new and there has been ample time for all of those things. They’re still in use because they’ve been shown to be safe when properly maintained
Not force from air pressure, force from the stress of the structure deforming applied to the windows.
Doubt that also....but if so nothing to do with the size of windows, more to do with design of superstructure
Possible the differential pressure due to the wind over the surface...you know, like what makes the sails work and helps planes fly...
Disagree.
Mine UK built by reputable professional yard, 10 years ago. It had no frits. Unsurprisingly the bond failed. Probably due to UV?
In my case turned out not to be a particularly big deal...but easily could have been.
I very much doubt that a tradional port light/window would have fallen out at 10 years old?
Besides, what is "properly maintained" ...exactly? By whom? Certified by whom? See benjenbav at #55.
I don't think it's irrational to take note of things that can fail catastrophically.
You might say that it's irrational to be afraid of sharks when bees kill many more people each year. But I would much rather be in a room with a bee than in the water with a great white. The shark only kills fewer people overall because we avoid the situation in the first place.
Keels rarely fall off, but very few people would put to sea if they had any misgivings about their keel. Cats are either designed with very conservative rigs, or sailed cautiously, which is what accounts for the lack of capsizes.
I know of two cat capsizes off the top of my head: one was an Outremer in Croatia where the main jammed and could not be dumped in a gust. The other was a 50ft French boat which was hit by a katabatic gust in Loch Nevis.
You'd be a fool to think that neither scenario could happen to you, just because the statistics are on your side.
