Delfini
My C Spars carbon mast of 15 years is down whilst the boat (Swan 48R) has a bit of work done and I asked the yard to check the rig - they reported the spreaders roots are a bit wobbly at the mast. After checking and confirming a few mm of wobble (mostly up and down) Ive removed the bottom spreaders and what’s left is a solid lump of aluminium (spreader bar) with fixing holes for the lower stay/s and the spreader itself and this bar just slides through the mast via slots each side. The spreader base seems to rest against the side of the mast via a stainless spacer shaped to fit the spreader base section
Over time the slots in the mast have worn a bit and it looks like the spreader bar is the primary cause which has mild corrosion in the area of the slot and acting as an abrasive
Does anyone have an idea of a fix - can I just make up the wear in the mast slot with epoxy filler or should I square off the slot and consider some sort of insert - if so what material would be best with a carbon mast and aluminium spreader bar ?
I would be grateful for any first hand experience of this problem or advice from any with Carbon rig knowledge
