Cabo Finisterre
Uricanejack
22 Oct 2012
Nice picture,
A Cape I passed many times. I don’t remember ever seeing, passed at night, bad weather or more often in fog, often stayed well offshore to avoid fog and traffic
I have seen the light and it’s loom from well offshore . It’s a nice big one. Ideal for a dipping range.
Looks like your having a great trip.
Bajansailor
27 Dec 2004
Marine Surveyor in Barbados
It’s not let us down yet. (There’s 40 metres of 10mm chain stowed behind it linked to another 50 metres of the same lower down and slightly further aft. )
That is an interesting arrangement - is the 50 metre section in a totally different compartment, or all in the same compartment with a divider, or something else?
I've been around Cabo Finisterre three times, all many years ago now - the first time we got pushed east of the rhum line and then had to beat our way around the Cape. Second time was a flat calm while motoring, and on the third we were hove to (in November '94....) in a gale 40 miles outside the shipping lane, and narrowly avoided being run down by a Chinese bulk carrier - their bow wave literally pushed us clear.
john_morris_uk
3 Jul 2002
At sea somewhere.
I’ve glassed in a pipe from the chain locker that’s right in the bow back to a space below one of the ‘V Berths’ in the f’wd cabin. The 90 m of chain is in one long unit and is available if needed, but it’s too long to self stow in the chain locker in the bow. You have to have a crew member pushing the pile over periodically as the pyramid it forms blocks the hawse pipe. I tried cones etc in the locker under the fall but nothing worked)
My modification of a pipe to stow part of the chain in a separate compartment also brings the weight down and aft slightly.
The extra 50 metres doesn’t self stow, but 40 metres of chain is enough for most anchorages we use.
laika
6 Apr 2011
London / Gosport
Having the same chain locker as you and 70m of 10mm we found the same thing. My proposed solution was going to be changing windless and moving to slippery new high strength 8mm but given that 50m is about the max I’ve ever deployed and that maybe once or twice this seems a good idea. Is the end of the chain now anchored in the v berth locker?
