Babylon
Actually, having re-read the original post, I'd now suggest that the most seamanlike method would be to forget about sailing off the anchor but practice using the engine to slowly motor forward (into wind and/or tide whichever is the dominant force on each occasion) towards the anchor, then kill the throttle before you get there and slowly fall back. With practice you'll be able to judge just when to engage neutral - which will give you the confidence to then amble forward to recover as much chain as you can manage, before doing it again. Eventually the anchor will be straight-up-and-down and will break out of its own accord, following which you can recover a bit more before motoring out into deeper water to bring up the rest.
