Baltika_no_9
I'm not suggesting that isn't a valid step but you have to be careful in what you infer from that. Even if you do see +12V ish with the key turned it does not rule out a high resistance key switch.1. Check the key switch feed (thin wire on the solanode). Pull it off and use a multi meter to test it goes to +12v ish (black wire on multi meter to batt -ve.) When you turn the key.
