Battery cables
ghostlymoron
9 Apr 2005
Shropshire
I'm re-locating the batteries on Cobblers and need longer cables. Can anyone advise what size I need for a Dynastart ? The length will be about 5'
Need to know the max cranking current. Maybe your engine manual contains the information
But assuming 5ft means 10 ft total positive and negative cable length
20mm² would be suitable for 100amps. Double the cross-section for double the current ie 40mm² for 200 amps Interpolate for current in between.
The manual states that the starter motor output is 1hp but I can't find a reference to CCC. The existing battery cables are 10mm o/d (including plastic sheath) which works out as 50mm2 assuming the insulation is 1mm - this seems excessive. Total there and back length is 10' as you correctly assumed.
1HP is 62A at 12V. There is a notable surge current which will be limited by total resistance. I would go 25mm^2. The cable can't be too thick but practically 25 will be fine.
1 Hp is the maximum mechnical power output The electrical input will be significantly higher.
some figures I have for an ordinary 1.1 hp starter motor are:
no load 30 - 50 amps
loaded 185 - 225 amps
stalled 400 - 490 amps
I would allow for something in the range 150 to 200 amps
If it's 1hp out mechanically it'll be around 1kW in electrically - 80A @12V. I recently rewired my 1GM10's 1kW starter using 30mm2 for the earth (because it's shared with everything else) and 25mm2 for the supply. I also replaced the old screw-clamp battery terminals with stud type and proper terminations on the wires. The engine now bursts into life first press whereas before it always took a few press-thunks before it would deign to turn over.
My cable runs are about 3m each way.
