Wago bits
Superglue may not perform well in damp environments. There are better glues for this. But that does look very neat. Is it covered with a protective panel?
You could use wago boxes. They also have cable restraint built in.
Do wago do rail mount connectors? I see rail mount mentioned earlier in this thread.
No need for boxes. The boat is bone dry. The glue seems to work OK. The first panels I made are now nearly 4 years old and no sign of failure. Using the glue is easy. Just a dab on the back of the Wago and press it down for 30 seconds and it is done.
See post #12
This is the small panel I made up for connecting the cables from the mast. Wagos stuck onto the board with superglue. I have use similar in a variety of places in rewiring the boat.
That's a neat way of doing a small number of connections, i've used that method a few times. I would add some better cable support though, the white "clip" still allows movement. A cable tie saddle roughly beneath each screw would be ideal.
This is the small panel I made up for connecting the cables from the mast. Wagos stuck onto the board with superglue. I have use similar in a variety of places in rewiring the boat.View attachment 204204
I'm possibly going to use something like this for all my mast wires. I do need to have a better look as to how many wires there are. The boat is new to me and the wiring needs some serious TLC.
https://www.screwfix.com/p/wago-32a-wiring-centre-junction-box-225-x-145-x-50mm-white/527pf
When I personally wired up the boat I built 1998 to 2009 I also used din rail and din terminal of various sizes mainly 1,5, 2,5 4 mm and bugger depending on the wire ; current capacity with pin crimps held on wire numbers.
Thin wiring for LED's I used ring connector with screw connector so mufti rings sonnectoree again with wire numbers
Vers large current cables use 8 mm ring/ screw connectors using 3/4 copper bars a connectors
Having an engineering work shop at home I can manufacturer bus bats of any size I with
Distribution panel
Distribution panel
I wouldn't call that a bodge as it looks excellent. Using the perforated trunking allows you to keep the wiring neat and add or remove wires easily.
I have built many large panels like this and it is the only way to go for a complicated system. DIN rail terminals come in many varieties for different sized cables including fused, switchable, LEDs, relays and can be commoned together with screw or plug in bus bars. Sprung contacts are reliable and top entry terminals make it easy to insert the wires.
There is a huge choice from Phoenix Contact, Wago or Entrelec and even a 15mm DIN rail range if you are short of space. Using different coloured terminals allows you to differentiate different circuits.
It is a bit like Lego for grown ups and quite satisfying to clip it all together.
Distribution panel
Impressive!
Careful with that. Moisture is not the only reason for boxes, as your house wiring demonstrates. Wago 221 fittings do NOT meet the pull out load requirements of ABYC or USCG. Even wire nuts have better pull-out strength (tested). They are quite weak at the low end of sizing (instruments). Secure the wire. You also want to make certain when you skip boxes that there is no way for anything to fall against the wiring. In other words, the location must be in important ways equivalent to a box. Not the same as a crimped and heat shrinked splice. You may know this, but I fear some may not.
Wagos are neat, but they have their limitations.
