prv
Although I'm ignoring it for now in favour of going sailing, KS is urgently in need of an electrical refit. I'm thinking things through now ready to do the work over winter. As well as taming the impressive rats' nest one of the things I'd like to do is fit a significantly bigger service battery, since it's rare for me to have shore power (never, so far, including at the home berth) and I often sail single-handed relying on the tillerpilot which must draw some amps.
Unfortunately, KS is not trimmed terribly well fore and aft. The previous owner fitted a bigger engine, and also placed a holding tank where the fuel tank belongs, forcing me to fit a new fuel tank right in the stern. To mitigate this he put a small chunk of lead in the forward locker and upgraded the ground tackle to all-chain, but she's still down at the stern and up at the bow by a couple of inches each.
The point is, I'm considering mounting the new battery up forward instead of in the current battery locker under the cockpit. I'd leave the engine battery where it is (possibly fitting a smaller-capacity, high-cranking type) but put the service battery which is likely to weigh 50Kg ish under the forepeak. Clearly this would be a nonsense from an electrical point of view in a 35-footer, but on KS this would only be 10 feet or so from the engine and panel (in a straight line; add another couple of feet for wiggling around). The biggest current flow is likely to be charging; otherwise the biggest loads are probably fridge and tillerpilot.
Is this too far?
I'd also end up running the cables alongside the sounder one; I guess DC shouldn't be causing interference?
Cheers,
Is this too far?
Cheers,
