Battery bank to inverter...cable size?
Trop Cher
17 Aug 2007
The Minch
Hi,
What size cable would I need for a two metre run from the battery bank to an inverter 1500w nominal power / 3000w maximum power?
Many thanks
VicS
13 Jul 2002
Hi,
Many thanks
Yiou dont say what voltage the system is but assuming 12 volts
Allowing 3% volts drop ( ie 0.36volts)
Taking the total cable length as 4m ( ie 2m positive and 2 m negative)
For 3000watts
I calculate that the cable should have a resistance of no more than 0.36 ohms/1000m ie somewhere between AWG 1 and AWG 0, say about 50mm²
VicS
13 Jul 2002
It's not a great length of cable, so go for the biggest you can reasonably fit. Certainly 70-90mm2.
On reflection safe current carrying capability is probably the deciding factor rather than volts drop is this case.
If the cables are in free air AWG 00 will be adequate but if bundled together with other wiring AWG 000 would be more appropriate
AWG 00 is a little less than 70mm² AWG 000 is 85mm²
Trop Cher
17 Aug 2007
The Minch
Many thanks for the replies :)
It is indeed a 12 volt system and four metres total run, therefore I've decided to go for 70mm cables. Thanks also for the links to sites which I've read and saved.
JumbleDuck
8 Aug 2013
SW Scotland
It might be worth remembering that 2 x 35mm^2 is (a) a lot bendier than 70mm^2 and (b) dissipates the heat better. Takes up a wee bit more room, though.
prv
29 Nov 2009
Southampton
For 12.5 volts in a healthy system, but taking the worst-case 3000W draw, my volt-drop spreadsheet comes up with an acceptable 2.8% loss using 50mm^2 cable.
