Plum
I have recently replaced my PVC rubbing strip insert. I measured it as 18.01m long so ordered, in December 2024, 19m of PVC-1022 from PVC 1022 for £111 including VAT and postage. This insert is manufactured by Wilks, in Tollesbury, UK, but Wilks were charging £210 including VAT but excluding postage. I called Wilks, who are a 30minute drive from my house, to ask why the big price difference but they said that was due to the big discount they gave Technix Rubber and could not give me the same discount. When I ordered from Technix Rubber the package came despatched from Wilks in Tollesbury! luckily this insert is sold in standard lengths, one of which was 19m, just right.Hi
Many thanks for the quick answer - I was hoping it wasn't going to be too expensive - 450E is still a lot for a bit of metal but that's a bit less than what I expected thankfully. At least it's not a Volvo part!
Thanks for the rubbing strip details too - that's also good to know.
Do you know if it's an easy job or hard work to fit? I was wondering if it is fixed one end with a locking screw then simply pressed in all the way round then fixed at the other...
Hopefully
However, this insert is bigger than the Beneteau insert and takes considerable effort to force it into the aluminium extrusion and took me 4 hours, even with some lubrication (Vaseline), to force it in so you need patience and a lot of effort. If you look closely, there is a very slight bulge in the insert where it fits over each of the screws holding the aluminium extrusion to the hull. You have been warned!
I made a join at the bow which is mostly hidden from view under the bow-roller and anchor.
The aluminium end caps, either side of the transom gate, were very corroded so had to fit new ones.
