PEJ
I was watching a video on setting and anchor and the bloke dropped his anchor, backed off whilst letting out chain off the windlass and got his desired length of rode out. He snubbed the chain off and then put it in reverse, idle speed, until the rode was tensioned and showed how the anchor was dug in because with the engines in reverse idle the boat was not moving.
Is that the right way? Do you keep reversing in idle until you stop moving with all the scope out?
I have usually let about half out whilst backing off, go in to neutral and drift back, wait until you feel the tension and usually see the bow drop a little and taken that to be the anchor setting and the let out the rest of the scope whilst backing up.
He also mentioned a quick thrust to make sure it set if necessary.
How how do you chaps make sure your anchor has dug in?
