An Attempt to board a Yacht off Portugal
cherod
N/A
2 Dec 2018
My point is you aim a barrel at me I'm not going to assume it's a fairly harmless air rifle, I'm going to assume the worst and if I'm carrying a gun you've had it.
but if you read the OP ( carefully ) you will see no reference to the " pirates " being armed , i think the inference is that they were not .
chrishscorp
4 Jan 2015
Live in Fareham Area, Boat in Gosport
I assume you would have to be a trained SBS sniper to attain that accuracy even from a large ship at speed...
Yes pretty much and he uses a rather expensive set of sights, after dialing in your boat speed and wind speed it does the maths and red dots what you are aimed at or will get a .5" round so close you will want new pants. He normally gets taken off the boat 12 miles out in international waters as there is too much paperwork involved to go into a port with guns
cherod
N/A
2 Dec 2018
12 volts wont be enough, pig fence is good at 18,000 volts wont kill but would brighten their morning, only issue electric fences give you is the electrical interference it could knock out the VHF whilst its switched on.
how do you get 18000v from a 12 v battery ?
HissyFit
13 Jul 2020
Pigs, unlike humans, can't grab onto wires so can escape when shocked. You don't want to trap the criminals but to send them away chastened.
chrishscorp
4 Jan 2015
Very simple. Just convert 12V at highish current to 18000V at lowish current. I've built transformers which will do this many times, although the simplest way is probably to use an old car HT coil.
Richard
Yes transformer off a car battery, HT coil is probably a cheap way of doing it, Pig fence would be safe/ non lethal to human
